landk
Jan 04, 2022Tutor
R6900P no longer showing all the devices on my network - factory reset and same issue ???
R6900P no longer showing all the devices on my network - factory reset and same issue ??? Same issue in web app on multiple computers and in the android nighthawk app ??? This issue has been an is...
Jan 04, 2022Guru - Experienced User
do they show up in the access control list?
That router's initial firmware release was in 2017 with the most recent in september of 2021. Its not showing up as EOL (end of life) so there might be further updates coming but netgear doesn't release any info on upcoming firmware updates
- landkJan 04, 2022Tutor
Yes
- landkJan 05, 2022Tutor
Any assistance regarding this issue would be greatly appreciated!
- plemansJan 05, 2022Guru - Experienced User
You have options.
1. leave it as is and use the access control list to see what device is on what IP address or connected
2. try downgrading the firmware. maybe the latest caused the issue.
