msetzerii's avatar
msetzerii
Follower
Sep 02, 2024
R6900P not changing Base IP
Was trying to change base IP from 192.168.1.1 to 192.168.30.1.
Make change and it shows the changes, but then click apply and it goes thru process, but then returns to the same 192.168.1.1?? Can't have two wifi's using the same address??
So what is screwed up. Gives no errors, just doesn't take change?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Start there. What do you really want to achieve?
    What do these WiFi sources come from?
    The "base IP" is the router's address on your network. What else do you have there? Another router? A modem router?
    Just another user with time on their hands.
