txakura
Dec 28, 2020Aspirant
R6900P ROUTER: I keep getting firmware upgrade notices, but then Nighthawk app says there are none.
For the second or third time in the past coiuple of years, I received an email purportedly from Netgear telling me there was a "security" firmware update for my router. When I went to the Nighthawk app on my tablet, however, I was told there were no updates. Was this a "phisihing" email, or don't I need the update - or does the Nighthawk app have a problem?
1 Reply
Which firmware version are you on?
You can see the versions on the support site to compare.
https://www.netgear.com/support/product/R6900P.aspx
the emails sent out aren't always the most accurate.
