Coldrunning
Mar 11, 2021Follower
R6900p slow wifi speed
S/N: 5JB1857EA0EFE Firmware: V 1.3.2.134_10.1.66 Spectrum 400 speed for download when direct connect to the KnightHawk. Using wifi only 48 speed download. From reading the forums, it see...
Mar 11, 2021Guru - Experienced User
What device are you speed testing on?
Are you testing over 2.4ghz or 5ghz? (2.4ghz is much much slower)
What modem is it connected to?
Did this just start?
Bullet-1992
Aug 27, 2021Aspirant
I am not getting my full speed from my Nighthawk router through wifi. Did factory reset and everything. Please help
- plemansAug 29, 2021Guru - Experienced User
Bullet-1992 did you start your own thread? We'd be happy to help if you'd start your own thread
