Coldrunning
Mar 11, 2021Follower
R6900p slow wifi speed
S/N: 5JB1857EA0EFE Firmware: V 1.3.2.134_10.1.66 Spectrum 400 speed for download when direct connect to the KnightHawk. Using wifi only 48 speed download. From reading the forums, it see...
michaelkenward
Aug 28, 2021Guru - Experienced User
48 Mbps is the fastest speed that you can expect to get for some wifi clients.
The router can supply a gazillion Bps, but if your wifi device crawls along at 48 Mbps, that's it.
If you take this wifi thing to a different wifi source is it a lot faster?
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
