Sparky66
Mar 09, 2019Tutor
r6900P Wired Ethernet Speed is extremely slow
Replaced ISP provider router with Nighthawk to improve wifi coverage. Wired and Wifi speeds are dismal at best. If I plug directly into ISP ethernet speeds are: 866.06 Down and 519.37 up. Wired th...
- Mar 13, 2019
For all those struggling with reduced download speeds...
I chatted with support and they graciously sent me a new router after much discussion and a few tweaks to MTU with no success. Upon receipt of the new router I plugged it in, turned it on basically matched my hardwire speeds out out of the box... See pics below. Over night router updated to most current firmware which was Version 1.3.1.44.
After the update I was back to 25% speed compared to straight ethernet to my ONT device. So I reverted the firmware back the version that the replacement router came with (R6900P-V1.3.0.20_10.1.1) and no issues...
Version 1.3.1.44R6900P-V1.3.0.20_10.1.1
Sparky66
Mar 10, 2019Tutor
Anyone experiencing this...?
- Sparky66Mar 13, 2019Tutor
- myerswMar 18, 2019Master
Glsf to hear the replacement is doing the job.
- vanmikeMar 17, 2019Aspirant
Yes I'm having the same problem... about 1/4th the wireless 5G download speed compared to wired connection. Is reverting the firmware my only option?
