ls2chevyastro
Sep 05, 2021Aspirant
R6900v2 DNS Not Working
I'm running a pihole on my server and when I change the DNS in the router it says it's been changed to 192.169.1.243 but all my network devices show the DNS as 192.168.1.1. I've tried rebooting everything, different firmware. Nothing works. Any ideas?
ls2chevyastro wrote:
....all my network devices show the DNS as 192.168.1.1.
That's your router's IP address.
I'm running a pihole on my server and ....
There's a steady flow of traffic here from pihole users. You might find something helpful with a local search.
Search - NETGEAR Communities – PiHole
- ls2chevyastroAspirant
That's where you are wrong, the dns should show my dns server not the routers ip
Not really. Indeed, not wrong at all.
I described what your screenshot does show. That is the router's IP address unless you have changed it.
What it should show, and why it does not show it, is another matter that I carefully avoided. Which is why I suggested places where you could look.
It isn't Netgear's job to tell you how to configure your system for PiHole.
