macmike100
Mar 24, 2022Aspirant
R6900v2 not port forwarding
Following instructions carefully but not working. My cams are set to be static. But have a couple still dynamic just as as a test. None port forward. I can see them on LAN fine I used to have an old...
Mar 24, 2022Guru - Experienced User
Be sure to disable uPnP if you set up any PF rules.
Something to contact the mfr of these cameras about and see if they have information regarding there product...
- macmike100Mar 31, 2022Aspirant
Returned unit for a refund. Even the Netgear tech couldn't figure it out. So I went back to my old ancient Linksys router. It worked with no problems. Slow as snot but I can at least view my home security cams from afar. I guess that's my best situation. So I'm over it now. Thanks.
