Kholley
Oct 10, 2021Aspirant
R6900v2 power button blinking
The links I was sent from netgear are no help. I’m not sure how to fix the issue. I’m not able to check the ISP connection and DNS settings, upload firmware to a NETGEAR router using Windows TFTP, or ...
Oct 10, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Kholley
I’m not able to connect my computer with Ethernet cord, so how will all of these steps work?
- plemansOct 10, 2021Guru - Experienced User
Why can't you?
- KholleyOct 10, 2021AspirantMy laptop doesn’t have an Ethernet port on it. So
I’m at a loss- plemansOct 10, 2021Guru - Experienced User
Options?
1. buy a usb--->ethernet adapter
2. borrow a laptop/pc to try it
3. if you're still within warranty, you can try opening a support ticket to see about rma. If you're not, then you'd need to try one of the other options to fix it as you'd need to be hardwired in to fix it.
