Kholley
Oct 10, 2021Aspirant
R6900v2 power button blinking
The links I was sent from netgear are no help. I’m not sure how to fix the issue. I’m not able to check the ISP connection and DNS settings, upload firmware to a NETGEAR router using Windows TFTP, or ...
Kholley
I’m not able to connect my computer with Ethernet cord, so how will all of these steps work?
Oct 10, 2021Guru - Experienced User
Why can't you?
- KholleyOct 10, 2021AspirantMy laptop doesn’t have an Ethernet port on it. So
I’m at a loss- plemansOct 10, 2021Guru - Experienced User
Options?
1. buy a usb--->ethernet adapter
2. borrow a laptop/pc to try it
3. if you're still within warranty, you can try opening a support ticket to see about rma. If you're not, then you'd need to try one of the other options to fix it as you'd need to be hardwired in to fix it.
