KevDawgg
Jul 15, 2022Novice
R6900v2 Router won’t connect to WiFi
R6900v2 router firmware is V1.2.0.92 I’ve had the netgear router for about a year. Therefore all my warranties are expired, and cannot get netgear support. I have an Xtream modem from mediacom. My r...
Jul 15, 2022Guru - Experienced User
What modem model is it?
Did the wifi on/off button get hit? Try pushing and holding that for 2 seconds.
If you hardwire a pc/laptop into the router, are you able to access or use it?
