millersdad's avatar
Jun 01, 2019
R6900v2 won’t allow nest thermostat to connect after router password change
For security reasons I had to change the password in my AC1900 model R6900v2 WiFi router. Reconnected tablets (both iPad and android based) along with Roku streaming devices without issue. When I inp...
  • millersdad's avatar
    millersdad
    Jun 01, 2019
    Nest passed it off as a router issue. After checking the various settings on the router, I went back and found others on the Nest site experiencing similar issues and did a factory reset on the thermostat itself. That solved the issue. Thanks for the assistance.
