Pbodnar's avatar
Pbodnar
Follower
Jul 16, 2021
R700 needs frequent reboots ,is always going offline
  • Mine is doing the same thing.  Losing signal and rebooting. Using firmware V1.0.11.106_10.2.100.  Never had a problem until the last 2 weeks....
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to revert the firmware to see if the reboot stops happening?
    DarrenM
    • Volstate's avatar
      Volstate
      Apprentice
      I used the hotfix and it seems to have fixed the issue
