Mariocarr
Feb 26, 2022Tutor
R700
Il router si resetta e non ci si collega con la wifi
Feb 26, 2022Guru - Experienced User
In inglese per favore
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- MariocarrFeb 26, 2022Tutor
The actual firmware is 11.023
I use channels 5 and 2,4 in auto mode
I have not other connection near to me.
I traied to reset the appliance but now only the first led is on and all the other are off.
- FURRYe38Feb 26, 2022Guru - Experienced User
My internet server provide is Vodafone. I have disconnected the R7000 from router, but the problem it's the same
- michaelkenwardFeb 27, 2022Guru - Experienced User
That's not a Netgear firmware number.
The version on my R7000P, as listed in your first footer, is V1.3.3.142_10.1.75.
For the R7000 it is 1.0.11.134.
- MariocarrFeb 27, 2022TutorMy firmware is: V1.0.11.126_10.2.112
But if I serch a new version, it doesn’t exists
