Mariocarr
Feb 26, 2022Tutor
R700
Il router si resetta e non ci si collega con la wifi
Mariocarr
Feb 26, 2022Tutor
The actual firmware is 11.023
I use channels 5 and 2,4 in auto mode
I have not other connection near to me.
I traied to reset the appliance but now only the first led is on and all the other are off.
Feb 26, 2022Guru - Experienced User
- MariocarrFeb 26, 2022Tutor
My internet server provide is Vodafone. I have disconnected the R7000 from router, but the problem it's the same
- FURRYe38Feb 26, 2022Guru - Experienced User
If your having same problems on the ISP wifi router, then you'll need to contact the ISP for help and information regarding there services.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
