Psychosis
Jul 24, 2018Aspirant
R7000 - Cannot access some websites and LAN port is amber
New to this community. Just bought an R7000 a few days ago and set it up with the app on my phone. My Xbox 1 works fine hard wired, the wireless and hard wired laptop works fine to an extent. I cant ...
- Jul 24, 2018
... and browsers are getting pickier and pickier about these things.
How about using the Advanced button? This will usually let you override the warning and get you into the site.
IrvSp
Jul 24, 2018Master
Besides what microchip8 posted, it could also be the cable being used, must use at least a CAT 5 for 1Gbs.
Website problems can be due to the DNS used which is why the Google ones were suggested but it could also be where you are possibly? What is the ERROR MESSAGE you got when you tried to go there? That might give a clue why if the Google DNS's don't work? Possible site problem too, when I just tried to go there my ISP put up this page, http://www.dnsrsearch.com/index.php?origURL=http%3A//ebenefits.gov/&r=&bc= and it implies a DNS error, or possibly site down? Possible you had the wrong URL? This one might be the correct one, https://www.ebenefits.va.gov/ebenefits/homepage?
Psychosis
I used a cat 7 first and it was still amber, now it has a cat 5e connected, still Amber.
- PsychosisJul 24, 2018Aspirant
Its an older laptop so it probably has the slower port on it.
- microchip8Jul 24, 2018Master
looks like a certificate issue of the website. I doubt it has anything to do with the router, unless you're using VPN
- michaelkenwardJul 24, 2018Guru - Experienced User
Psychosis wrote:
I used a cat 7 first and it was still amber, now it has a cat 5e connected, still Amber.That is a strong indicator that your laptop has an Ethernet port that works at 100 Mbps.
Apart from getting a new laptop, there isn't much that you can do about that.
How fast is your internet?
- IrvSpJul 24, 2018Master
Actually you can as long as the laptop has a USB port. Disable the on-board network adapter and using a USB 1Gb network Adapter (or wireless).
I did think about that but wondered if there is any point. Local stuff would certainly benefit but unless they have fast broadband 100 Mbps, there won't be much to be gained by this when it comes to internet speeds.
Hence my question about internet speed.
200mbps here.
