Psychosis
Jul 24, 2018Aspirant
R7000 - Cannot access some websites and LAN port is amber
New to this community. Just bought an R7000 a few days ago and set it up with the app on my phone. My Xbox 1 works fine hard wired, the wireless and hard wired laptop works fine to an extent. I cant ...
- Jul 24, 2018
... and browsers are getting pickier and pickier about these things.
How about using the Advanced button? This will usually let you override the warning and get you into the site.
Psychosis
I used a cat 7 first and it was still amber, now it has a cat 5e connected, still Amber.
Psychosis
Its an older laptop so it probably has the slower port on it.
- microchip8Jul 24, 2018Master
looks like a certificate issue of the website. I doubt it has anything to do with the router, unless you're using VPN
- michaelkenwardJul 24, 2018Guru - Experienced User
- PsychosisJul 24, 2018Aspirant
I had to go into the tools menu in the browser and mess with a couple security options. It all works now. Thanks for all the info everyone.
