Psychosis
Jul 24, 2018Aspirant
R7000 - Cannot access some websites and LAN port is amber
New to this community. Just bought an R7000 a few days ago and set it up with the app on my phone. My Xbox 1 works fine hard wired, the wireless and hard wired laptop works fine to an extent. I cant ...
- Jul 24, 2018
... and browsers are getting pickier and pickier about these things.
How about using the Advanced button? This will usually let you override the warning and get you into the site.
Duka2
Jul 31, 2018Aspirant
im having a problem resetting to factory settings. i've held the reset button for 10sec, and with ethernet cable enter www.routerlogin.net and it will not accept admin and password. then it asks for the serial number and when i enter it, it says it doesnt match. i log into my netgear account and it shows the same serial number?? what do i do now? help anyone
michaelkenward
Jul 31, 2018Guru - Experienced User
Probably start a new conversation.
You have joined in on an older discussion, so there's a chance that the official support team will be too busy following new stuff to find your message. It is usually better to start your own fresh discussion if you want their attention.
This is especially important when you join a conversation marked "solved". The official team has an even better reason for moving on to new queries.
