JaedonNelson
Apr 09, 2020Aspirant
R7000 - Can't Log into Router
I recieve this error when attempting to log into the Router Access Page "You may not be connected to your Router’s WiFi network. To access routerlogin.com, your device must be connected to your Route...
- Apr 19, 2020
I figured out the solution to my problem, it turns out the AT&T modem/router was attempting to be the DNS whenever I tried to access the routerlogin.net page or using the IP address. I isolated the Nighthawk router completely and then I was able to connect to the login page and gain access to my router once more.
JaedonNelson
Apr 19, 2020Aspirant
