Jennienewland
Aug 05, 2021Initiate
R7000 - configuration
I am trying to check if there is a setting on my router called SIP-ALG and if so disable it but I am unable to find how to check the configuration. I've tried going to routerlogin.net but it doesnt ...
- Aug 05, 2021
here's how to disable sip alg.
If your not able to get in either because of wrong password, unknown password, or password recover wasn't setup then you'd need to factory reset to get back in. push and hold reset for 7-15 seconds while powered on. that'll reset everything back to stock.
Aug 05, 2021Guru - Experienced User
Jennienewland
Thanks, that's fixed it!
