bjtech
Jan 22, 2018Tutor
R7000 - Connected Devices Lose Connection w/ Newer Firmware
I cannot upgrade past firmware version 1.0.9.6 without some of my devices randomly disconnecting. In particular, I have two Ecobee 4 thermostats that will lose connection within a few hours of upgra...
- Jan 28, 2018
Hi bjtech,
Please try this firmware.
https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix
bjtech
Feb 04, 2018Tutor
wrote:Hi bjtech,
This firmware has worked so far!
I have not lost connection for over 5 days (at least that I am aware of).
Previously, the connection never lasted past 24 hours. And once it lost connection, it never reconnected until after a fullrouter reset.
JamesGL
Feb 08, 2018NETGEAR Employee Retired
Hi bjtech,
Thank you for the feedback.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
