scavdog
Jun 09, 2021Aspirant
R7000 - intermittently losing internet
I have had my Nighthawk R7000 for about 2 years with relatively no issues. The last 2 weeks I have been losing internet sporadically. If I catch it immediately the router will not allow me to log i...
Jun 09, 2021Guru - Experienced User
What firmware are you on?
scavdog
V1.0.10.90_10.2.90
- plemansJun 09, 2021Guru - Experienced User
the recent firmware is 1.0.11.123 for the R7000. I don't even see your version listed as a prior version.
If you do indeed have the R7000, try updating over a hardwired connection. Then do a factory reset and reinstall.
