scavdog
Jun 09, 2021Aspirant
R7000 - intermittently losing internet
I have had my Nighthawk R7000 for about 2 years with relatively no issues. The last 2 weeks I have been losing internet sporadically. If I catch it immediately the router will not allow me to log i...
scavdog
V1.0.10.90_10.2.90
Jun 09, 2021Guru - Experienced User
the recent firmware is 1.0.11.123 for the R7000. I don't even see your version listed as a prior version.
If you do indeed have the R7000, try updating over a hardwired connection. Then do a factory reset and reinstall.
- scavdogJun 09, 2021Aspirant
It's on autoupdate - go figure
- plemansJun 09, 2021Guru - Experienced UserYou can manually update it.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
