Deb10
Mar 19, 2016Aspirant
R7000 - ISP Says My Router broadcast is Interfering w/ ISP's Incoming Wirless Signal
I have wireless ISP service. There is a 'radio' receiver on the roof which receives the signal from a repeater in the neighborhood - it is line of sight transmission. From there it is wired into t...
- Mar 21, 2016Deb- i work for a WISP and can help u out.
Are u in the US? If so heres some info for u.
Most WISPs use the same frequencies(2.4ghz and 5ghz) that wifi uses. This is because theyre free unlicensed freq. available for everyone to use. if a WISP used licensed freq, then the service would cost a whole lot more due to the FCC liscense costs.
When they say they can "see" your wifi signal, this means that your CPE(customer premise equipment) radio on the roof( which is acting as a station to the WISPs access point on their tower or building or wherever its located) is seeing the wireless signal that your router is broadcasting. A CPE is functioning similarly to what a phone or wireless computer does- it sees all the wifi signals that are available. This is normal.
The first thing u need to do is find out which freq band the WISP uses. If 2.4Ghz and all equipment u have operates on 5ghz(only talking about wireless devices here not wired), then u could turn off the 2.4ghz wifi on the Nighthawk.
However, if youre like most people, u will have a mix of devices where some have older 2.4ghz only radios.
In that case, the best thing u can do is make sure youre on a different channel than what the WISP is using. For 2.4ghz, theres only 3 non overlapping channels- 1,6,11. This means, if youre on chnl 1 and the wisp CPE is on 3, then there will be interference between the WISP CPE and your router.
If the WISP CPE instead uses 5Ghz freq then its a little more complicated due to MIMO and upper and lower channeling.
Once u separate the 2 devices as far as channels go, moving your router farther away from the CPE should help.
As far as IP address allocation goes, that has nothing to do with wireless signal interference between the 2 radios. IP address conflicts is a whole nother issue. If youre having that issue as well, it can easily be fixed. But lets get the wireless interference issue fixed first.
Hopefully this helps. If u have any questions, feel free to ask away!
BryanSD
Mar 20, 2016Apprentice
I always find it strange that Wireless ISP (WISP) would pick a frequency range to transmit your WAN services as the same used for a Wi-Fi LAN. How do they know it's you and not one of your neighbors that interfering with your signal?
If you're on Channel 1 and they're on 8 have you verifired that this isn't a channel width and overlap issue? It's possible your WISP's equipment has also a very wide channel width it receives. Just for troubleshooting purposes, have you tried with the Channel 1 to set your Channel mode to the lowest "up to" setting to the lowest value ("Up to 54 Mbps" )? Also, make sure you have enabled 20/40 MHz Coexistence (Advanced Setup > Wireless Settings > Enable 20/40 MHz Coexistence).
Deb10
Mar 20, 2016Aspirant
Thanks also for these suggestions . . .
re the frequency the ISP uses, they say they are mandated by the FCC to use that frequency, so it makes no sense to me why general market routers and what gets assigned to an ISP should conflict - government at its usual performance level.
I will go up on the roof & recheck the overlap with my wifi analyizer (phone model). Inside the house I do not see the ISP wireless signal, nor do I see any of my neighbor's, but I believe I should be able to see it and any other neighborhood routers that are strong on the roof. We are rural (hence the need for WISP) so the houses are not close together & neighbors' router signal interference is usually not a problem for us.
Hmm - I don't know what those 'Up To' settings are all about - but I will check it out! Same for the 20/40 MHz settings - no idea what they are - but I will check.
My brother was asking me if the ISP modem also assigns IP Addresses - apparently some do - and if it is trying to assign them and my router is also trying to assign them, there could be a conflict. I will check into that issue tomorrow too.
Thanks all so much for the hlep! Really appreciate it! I'll let you know if any of these things work. Deb
