ngsmudge's avatar
ngsmudge
R7000 - ReadyCLOUD/MyNETGEAR upgrade - now shows offline
I updated ReadyCLOUD to use MyNETGEAR account, and the unregistered/reregistered the router as instructed. However, now when I log into ReadyCLOUD (with the MyNETGEAR account), it shows the R7000 the...
  • ngsmudge's avatar
    ngsmudge
    Jun 01, 2016
    Found it!!  On my router, even though I had registered it through the Advanced > USB Functions > ReadySHARE Storage, when I went to Basic > ReadySHARE, it showed it set at Basic (radio button). When I clicked ReadyCLOUD radio button, it said it was registered, and viola, it was online on the ReadyCLOUD website.
    Don't know why both places had to be set, but at least it's online.
    Hope this helps if anyone else runs into this issue.
