nerevolution
Dec 04, 2017Tutor
R7000 - "Readyshare" path no longer working after Windows 10 version 1709 update
Ever since my PC updated from Windows 10 version 1703 (Creators Update) to version 1709 (Fall Creators Update), my Readyshare drive will no longer mount if I use the \\readyshare hostname. After ...
- Dec 06, 2017
Thanks James, but I actually already have it installed. I had seen that post before making this thread, and verified that it is installed.
I'm definitely puzzled, but at least I can still access it using the IP instead.
JamesGL
Dec 06, 2017NETGEAR Employee Retired
Hi All,
Check this link.
nerevolution
Dec 06, 2017Tutor
