RiveraChristian
Jul 29, 2017Follower
R7000 - Strict to Open NAT for PS4
I'm New so I may make several errors in the post, however I want to know if I turn my ISP modem/Router combo to Modem mode only (has that option in settings) will I be able to change my Nat type from...
- Aug 03, 2017
Hi RiveraChristian,
It is the reason why the NAT type is strict since you have to routers in the network. Set the modem to modem only.
Once done setting the modem to modem only, set the NAT filtering to open under WAN setup of the R7000.
https://kb.netgear.com/24085/How-do-I-view-the-WAN-settings-on-my-Nighthawk-router
JamesGL
Aug 03, 2017NETGEAR Employee Retired
Hi RiveraChristian,
- JamesGLAug 06, 2017NETGEAR Employee Retired
Hi RiveraChristian,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
