Dinky2534
Jan 21, 2021Star
R7000 - Time zone settings wrong after using Nighthawk android app
Why does my R7000 router adjust the timezone settings to the wrong time zone setting when using the Android app? The router is set to the GMT +1 time zone: (GMT+01:00) Amsterdam, Berlin, Bern, Ro...
- May 27, 2021
I've been running the 1.0.11.122 firmware for a few days now, which solved the problem with the timeserver!
Dinky2534
Jan 23, 2021Star
Problem also occurs on a Samsung A5 phone and a Samsung S6 tablet.
- Christian_RJan 28, 2021NETGEAR Employee Retired
Hi Dinky2534,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- Dinky2534Feb 11, 2021Star
Thank you for your response Christian,
Unfortunately, the 90 days of free support for this router has expired.
Sincerely,
Dink2534
- RyzenVarunFeb 17, 2021Initiate
I am facing the exact same issue on a Netgear R7000P AC2300 router. have tried it number of times though the moment i access the router to even view the settings or how many devices are connected and exit the app. and login tothe router using the web interface the timezone is off by 30 minutes in my case.
using the latest version of the firmware as available in the R7000P downloads page. (V1.3.2.134_10.1.66)
I suspect it is the router and App combination that is causing some misalignment.
a similar setup with Samsung Note 8 and Netgear 6350 router did not face any such issue.
Samsung note 10 and Netgear 6350 did not face any issue.
the moment you access the R7000 or R7000p and even view the stats or config / devices using the nighthawk app something gets knocked out in the netgear router.
Instead of using GMT +530 the timezone gets reset to GMT +5
even using a different ntp server does not prevent this problem.
and when you login to the router after having accessed it via the nighthawk app, you get this funny error message
"Need to auto config timezone?"
Ok / Cancel.
