Dinky2534
Jan 21, 2021Star
R7000 - Time zone settings wrong after using Nighthawk android app
Why does my R7000 router adjust the timezone settings to the wrong time zone setting when using the Android app? The router is set to the GMT +1 time zone: (GMT+01:00) Amsterdam, Berlin, Bern, Ro...
- May 27, 2021
I've been running the 1.0.11.122 firmware for a few days now, which solved the problem with the timeserver!
michaelkenward
Mar 09, 2021Guru - Experienced User
Hard to see how using a particular wifi client will cause the router to change its time.
I chip in simply because i have the same Samsung phone and have never seen anything like this when using the Android app.
If this is the Nighthawk App for Android, the version number looks wrong:
Dinky2534 wrote:Android app version: 2.8.0.1395
I have 2.8.5.1416 on my Samsung A5.
Dinky2534
Mar 09, 2021Star
Did indeed receive the Android 2.8.5.1416 update last week.
Just tried it. Also with the 2.8.5.1416 version, the time zone settings change after connecting via wifi.
- michaelkenwardMar 10, 2021Guru - Experienced User
What are the NTP settings on the router?
- Advanced
- Administration
- NTP Settings
I cannot remember anyone reporting this behaviour before.
- Dinky2534Mar 10, 2021Star
michaelkenward wrote:What are the NTP settings on the router?
- Advanced
- Administration
- NTP Settings
I searched forums but there was indeed little to be found about it ...
My NTP settings:
These are the settings when I have connected to the router via WiFi with the Nighthawk app and log in to the router again:
When time is resynchronized, or after reboot, it has been adjusted to wrong time zone:
Even if I use an preferred NTP server (pool.ntp.org) the same thing happens.
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
