Dinky2534
Jan 21, 2021Star
R7000 - Time zone settings wrong after using Nighthawk android app
Why does my R7000 router adjust the timezone settings to the wrong time zone setting when using the Android app? The router is set to the GMT +1 time zone: (GMT+01:00) Amsterdam, Berlin, Bern, Ro...
- May 27, 2021
I've been running the 1.0.11.122 firmware for a few days now, which solved the problem with the timeserver!
ksok
Mar 25, 2021Initiate
Same issue here. I try and try to set the time zone to Eastern and it defaults back to International Date Line West. It doesn't look like it's isolated so a fix would be appreciated.
- MadameCMar 27, 2021Tutor
I am having the same issue. I have tried every possible fix I can think of and nothing works.
- Dinky2534May 27, 2021Star
- GrandFlandersOct 30, 2021Tutor
MadameC wrote:I am having the same issue. I have tried every possible fix I can think of and nothing works.
Blow this up, I'm tired of the ongoing problem. My logs are a MESS.
- FURRYe38Nov 02, 2021Guru - Experienced User
Either contact NG support about this, don't look at the logs or don't use the NH app.
F*cking THIS, PLEASE.
ksok wrote:Same issue here. I try and try to set the time zone to Eastern and it defaults back to International Date Line West. It doesn't look like it's isolated so a fix would be appreciated.
