Dinky2534
Jan 21, 2021Star
R7000 - Time zone settings wrong after using Nighthawk android app
Why does my R7000 router adjust the timezone settings to the wrong time zone setting when using the Android app? The router is set to the GMT +1 time zone: (GMT+01:00) Amsterdam, Berlin, Bern, Ro...
- May 27, 2021
I've been running the 1.0.11.122 firmware for a few days now, which solved the problem with the timeserver!
MadameC
Aug 01, 2022Tutor
I found a solution that worked for me...your mileage may vary. I enabled "Location Services" for the browser I use to access my router settings webpage (also moved the slider for "Precise Location" to "on" in that Location Services menu.) I was then able to change my time zone and daylight saving time settings to the correct settings and they have STAYED correct so far! I hope this works for you...good luck!
MadameC
Aug 01, 2022Tutor
A clarification: the process above was done on an iPad. Your access to Location Services for your browser might be a bit different depending on your device.
