MistrT
Aug 04, 2021Tutor
R7000 - Ugraded my firmware to V 1.0.11.126 and now my 5GHz signal drops!
I just updated the firmware for my router last weekend and now I'm finding that my 5GHz signal is dropping randomly. It's very annoying and there's no reason. Everything has worked just fine for ye...
Aug 05, 2021Guru - Experienced User
did you try a simple factory reset and reinstall?
the R7000 has been a problem router for firmware updates. After updates, its responded favorably to factory resets.
if that doesn't help, you can downgrade the firmware to the prior version you were on.
MistrT
Aug 13, 2021Tutor
Factory reset seems to have helped so far. Thank you for the suggestion.
