Andarc777
Feb 28, 2022Aspirant
R7000 - Unable to update firmware
Evening all, I'm having a little trouble with a Netgear R7000 Router. I purchased this a couple of years ago, but it was never actually used. In a nutshell, it would appear that the router is o...
Feb 28, 2022Guru - Experienced User
Are you using the routers web page to update FW?
What browser are you using? Try MS Edge or FireFox?
.CHK is the correct file extension...
Your on a verson that isn't listed on NGs download page for this model router.
You might try 1.0.2.164 or some middle ground version of FW to see if you can get the router past v1.0.1x
- Andarc777Feb 28, 2022Aspirant
Hi, thanks for your reply.
Yes, using the router's web page. Tried Firefox, Chrome and Edge. All the same error.
Yup, pretty sure .chk was correct, but it just won't accept anything other than .img - see attached photo.
1.0.2.164 is also .chk - won't accept it!
Really strange.......
