Andarc777
Feb 28, 2022Aspirant
R7000 - Unable to update firmware
Evening all, I'm having a little trouble with a Netgear R7000 Router. I purchased this a couple of years ago, but it was never actually used. In a nutshell, it would appear that the router is o...
Feb 28, 2022Guru - Experienced User
Ok so for the v1.0.2x file, rename the .chk to .img and see if the router will accept it...
Ya, this is odd...
Andarc777
Unfortunately, it didn't like it. Error saying Firmware file was incorrect.
Really scratching my head with this one.
- FURRYe38Feb 28, 2022Guru - Experienced User
Ok last resort will be this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpawTry nmrpflash:
https://github.com/jclehner/nmrpflash - plemansMar 01, 2022Guru - Experienced User
It is correct. Look in the top left corner of your gui. You have a D7000.
Not an R7000.
They're different routers.
D7000 | Product | Support | NETGEAR
- plemansMar 01, 2022Guru - Experienced UserIf you use the correct firmware for your router, it'll work.
(thats what I meant by its correct).
