kochin
Dec 09, 2016Apprentice
R7000 & R6400 Vulnerability Note VU#582384
[When I created this post, I wasn't aware of the 2 discussions already on this topic: Two leading Netgear routers are vulnerable to a severe security flaw R7000 Vulnerability Note VU#582384] ...
- Dec 15, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information and update see the thread below.
kochin
Dec 11, 2016Apprentice
So far the best workaround of this vulnerability I saw is detailed at http://www.sj-vs.net/a-temporary-fix-for-cert-vu582384-cwe-77-on-netgear-r7000-and-r6400-routers/. Before you follow the procedure I suggest you to reboot your router first.
