kochin
Dec 09, 2016Apprentice
R7000 & R6400 Vulnerability Note VU#582384
[When I created this post, I wasn't aware of the 2 discussions already on this topic: Two leading Netgear routers are vulnerable to a severe security flaw R7000 Vulnerability Note VU#582384] ...
- Dec 15, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information and update see the thread below.
kochin
Dec 11, 2016Apprentice
I got a response from Netgear this morning at 2:39am. They must be working hard to get it resolved. But, the message isn't saying much.
We appreciate you contacting us. Currently we are working on a fix and will get back to you when it’s available. Thanks.
If you have any questions or comments with regard to this information, please contact us at: [email protected].
Sincerely,
Product Security Incident Response Team
Netgear, Inc
germanus
Dec 11, 2016Tutor
I got exactly the same email response from the security team. While it is very general it looks like Netgear knows about it and îs working on a fix.
I will stay put and not switch to my Comcast router which has much lower WiFi speed. Just will be very careful not to open any link, alerted my wife to be diligent with suspicious looking emails. Let's hope the Netgear team comes up with something soon.
- mdgm-ntgrDec 11, 2016NETGEAR Employee Retired
We (NETGEAR) are aware of the security issue #582384 affecting R6400, R7000, R8000 routers. Stay updated here: http://kb.netgear.com/000036386/CVE-2016-582384
We're working hard for a fix and will update the security ticket above soon.- Chaz84Dec 13, 2016Aspirant
So I found out from a friend an article in Wired online that directs you to the Netgear site for a firmware beta fix for the Netgear security issue. However, I downloaded the fix, but then it says to go to www.routerlogin.net in order to actually do the Firmware upgrade. I do that but it says that I need to be connected to my router's WiFi network. My computer does not have WiFi and I connect through an ethernet cable to the router. I thought ethernet is what they recommend for downloading firmware upgrades as it should be a more consistent connection, but the Netgear site is telling me I can only connect over WiFi in order to upload the Firmware I just downloaded. How do I then get the Firmware fix for this security issue if my only way to connect is via ethernet cable? The routerlogin.net site is telling me I can only do that via a WiFi connection.....HELP.
- mdgm-ntgrDec 13, 2016NETGEAR Employee Retired
If you know the I.P. address of the router you can just go to that instead e.g. http://192.168.1.1
The routerlogin.net is just a handy way to get to the router management page without needing to know the I.P. address. Both URLs are acceptable and work equally as well. I connected to my R7000 via I.P. to do the beta firmware upgrade and it worked fine.If the R7000 is not your main router or not connected to the internet that would explain by the routerlogin.net link didn't work.
If the routerlogin.net can't redirect to your router's web admin interface then we present a web page providing generic advice as to what you could try.
It's correct that it is recommended to connect via ethernet to your router to do a firmware upgrade.
Welcome to the community!
