kochin
Dec 09, 2016Apprentice
R7000 & R6400 Vulnerability Note VU#582384
[When I created this post, I wasn't aware of the 2 discussions already on this topic: Two leading Netgear routers are vulnerable to a severe security flaw R7000 Vulnerability Note VU#582384] ...
- Dec 15, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information and update see the thread below.
RMinNJ
Dec 14, 2016Luminary
The Security Advisory has been updated with more information and beta firmware for some models. ..."
Will this firmware shut off the telnet backdoor to the router or should we file another security report for that ?
kochin
Dec 14, 2016Apprentice
Not sure what telnet backdoor you were talking about. Did you mean the telnetd running at your router after you tested the proof of concept? Simply power your router off and then on, and it will be gone.
RMinNJ wrote:Will this firmware shut off the telnet backdoor to the router or should we file another security report for that ?
- RMinNJDec 14, 2016Luminary
Yes, but someone can send the "magic packet" to the router and telnet will be on again. I think the premise of the security lies in
the fact that that packet has to have the correct admin password? Would prefer if this turn on daemons via magic packets feature could be disabled..
- ElaineMDec 14, 2016NETGEAR Employee Retired
Hi All,
Also, for more information see the link below.
- kochinDec 14, 2016Apprentice
Thank you for the update. It shows that Netgear has the courage to admit their own mistake. I'll take that as a promising indication that Netgear will learn from this incident.
Once it had been disclosed that the first notification occurred in August, we conducted a search and confirmed this was the case. Admittedly, this was an oversight on our part.
