kochin
Dec 09, 2016Apprentice
R7000 & R6400 Vulnerability Note VU#582384
[When I created this post, I wasn't aware of the 2 discussions already on this topic: Two leading Netgear routers are vulnerable to a severe security flaw R7000 Vulnerability Note VU#582384] ...
- Dec 15, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information and update see the thread below.
mdgm-ntgr
Dec 15, 2016NETGEAR Employee Retired
You should prepare just in case to be able to re-enter your settings manually e.g. if you need to do a factory reset after the upgrade.
I had no problems but then I have a very simple configuration on my R7000.
jrgreenman
Dec 15, 2016Tutor
That's good advice, but I'm really wondering if others have flashed the beta and can confirm that their settings remained intact or, at least, that the new firmware is able to successfully restore settings backed up with the prior firmware.
You guys must have tested this in the lab, yes? Did it work for you?
