HyperLunatic
Jun 13, 2021Tutor
R7000 1.0.11.123 and 5Ghz
For those with older R7000 devices and have experinced intermittent and frequent wireless drops, especially in the 5GHz band, I think I may have a solution. After many, many, many times of trying to...
JWS9518
Jun 16, 2021Luminary
Just to update my testing of your setting..it did not work for me.. I still have the same issue with near daily once a day disconnect and the need to soft reboot....so no luck with setting to those parameters on my end.
HyperLunatic
Jun 16, 2021Tutor
@JWS9518… bummer. None of my R7000 devices are being use as primary WiFi anymore, was hoping to just get them working in case I needed them as back… at this point, they are headed for the trash can.
