cabeaulac
Jun 16, 2019Aspirant
R7000 1.0.9.x reboot cycle
My R7000 was bricked. After finally figuring out how to configure Terminal on MacOS to let me Ctrl-C the boot process so I could turn tftpd on, I can now reflash the firmware. Every version of the 1....
- Jun 20, 2019
I spent way too much time on this. :-(
Yes! I ordered a new power adapter. This one: https://www.amazon.com/gp/product/B06XWHS8G2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
And now the R7000 is working again.
So, if you think your firmware upgrade is causing your constant reboot cycle, it might just be your power supply. OMG.
cabeaulac
Just installed 1.0.8.34 and it came up all the way. Then rebooted after 15 seconds. Ugh. I'm enormously frustrated.
cabeaulac
Downgraded firmware to 1.0.7.12_1.2.5 and it's been running for 5 minutes so far. It's a record. Letting it run now...
Any clues why this is happening R7000 people?
- cabeaulacJun 16, 2019Aspirant
The router reboots when I connect a wifi device with firmware 1.0.7.12. Downgrading to 1.0.7.10. What version should I be using or is there some proceedure I'm missing?
- IrvSpJun 16, 2019Master
You could be having power supply issues?
I assume you have been doing the FACTORY RESET after each firmware change and re-entering settings manaully, not using a saved configuration? Not doing this can mask the problem and keep it happening.
- cabeaulacJun 17, 2019Aspirant
Sometimes I can do the FACTORY RESET. Sometimes I can't when the unit won't stay up long enough before rebooting on its own.
