cabeaulac
Jun 16, 2019Aspirant
R7000 1.0.9.x reboot cycle
My R7000 was bricked. After finally figuring out how to configure Terminal on MacOS to let me Ctrl-C the boot process so I could turn tftpd on, I can now reflash the firmware. Every version of the 1....
- Jun 20, 2019
I spent way too much time on this. :-(
Yes! I ordered a new power adapter. This one: https://www.amazon.com/gp/product/B06XWHS8G2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
And now the R7000 is working again.
So, if you think your firmware upgrade is causing your constant reboot cycle, it might just be your power supply. OMG.
cabeaulac
Downgraded firmware to 1.0.7.12_1.2.5 and it's been running for 5 minutes so far. It's a record. Letting it run now...
Any clues why this is happening R7000 people?
cabeaulac
The router reboots when I connect a wifi device with firmware 1.0.7.12. Downgrading to 1.0.7.10. What version should I be using or is there some proceedure I'm missing?
- IrvSpJun 16, 2019Master
You could be having power supply issues?
I assume you have been doing the FACTORY RESET after each firmware change and re-entering settings manaully, not using a saved configuration? Not doing this can mask the problem and keep it happening.
- cabeaulacJun 17, 2019Aspirant
Sometimes I can do the FACTORY RESET. Sometimes I can't when the unit won't stay up long enough before rebooting on its own.
0) plugged router into different surge protector
1) performed factory reset
2) waited for router to come back up, rebooted router and hit Ctrl-C in minicom window
3) started tftpd on router
4) sent R7000-V1.0.9.64_10.2.64.chk to router
5) router is rebooting continually (update it's hung)
ACSD >>acs_candidate_score_intf(2330): intf check failed for chanspec: 0x100b acsd: Netgear selected channel spec: 0x1009 control channel:9 Request finished Failed to open file '/etc/avahi/avahi-daemon.conf': No such file or directory ###################################mount openvpn mtdblock19 [ 29.710000] Empty flash at 0x000aa150 ends at 0x000aa800 [ 29.880000] Empty flash at 0x00441474 ends at 0x00441800 [ 29.910000] Empty flash at 0x004430d4 ends at 0x00443800 [ 31.960000] Empty flash at 0x00d9b0f0 ends at 0x00d9b800 [ 32.820000] Empty flash at 0x04033a9c ends at 0x04034000 [ 32.830000] Empty flash at 0x04034ac8 ends at 0x04035000 Digital core power voltage set to 1.0V Decompressing...done
6) All lights are blicking and router output on minicom has stopped here:
ADDR 0000000000111111111122222222223333333333444444444455555555556666 0123456789012345678901234567890123456789012345678901234567890123 00 +++++++++++++++++S+++++++++++++X++++++++++++++++++++++++++++++++ Decompressing...done
