tannerone
Nov 09, 2021Follower
R7000 100NA Power fades to nothing.
About one year old. Simply went out of service. No power. When power is first turned on the orange power lamp is bright. After a minute or so the power lamp fades to barely glowing. The other indica...
Nov 09, 2021Guru - Experienced User
Try a different power adapter with same volts and amps seen on the stock adapter...
