JohnNadeau
Oct 12, 2023Apprentice
R7000-100NAS vs R7000-100PAS
I'm comparing an R7000-100NAS (North American) vs an R7000-100PAS (European). I see that there are "physical differences" in that the NAS has removable antennas, while the PAS does not. Does ...
- Oct 12, 2023
Found it !
I used the FCC ID Number on my R7000-100PAS unit.
Page 49 indicates 29.10dBm
https://fccid.io/PY318300420/Test-Report/RF-Test-Report-4107484.pdf
michaelkenward
Oct 12, 2023Guru - Experienced User
That may be something that changed over the long life of this product.
First released in 2014, the R7000 was a mainstay of Netgear's mid-range routers for quite some time. It even continued to appear on the shelves after the R7000P came out in 2017. The latest manual I can find for the R7000 is from 2019.
To be clear, I'm NOT talking about the limitations of the Country Code/Revision. I am looking for the actual/physical capabilities of the Radios.
That may have changed too.
JohnNadeau
As it turns out, I found an FCC Test from 2018 that indicates 29.49 dBm.
https://fccid.io/PY313200233/Test-Report/RF-Test-Report-3854129.pdf
I would assume this would be the North American R7000-100NAS model given the test by the FCC.
Now I just need to find the European equivalent of the FCC for the 100PAS version đ
- JohnNadeauOct 12, 2023Apprentice
Found it !
