andrewtmartin
Jan 18, 2022Tutor
r7000 192.168.1.1 didn't send any data
I have an R7000 operating with firmware version V1.0.11.116_10.2.100 When I try to manually update the firmware (because automatic update does not work) to any version above V1.0.11.116_10.2.100 ...
Jan 18, 2022Guru - Experienced User
Are you attempting this over a hardwired connectin? over wifi?
What device are you on?
Have you tried a different pc/laptop?
Have you tried a different web browser?
andrewtmartin
Jan 19, 2022Tutor
Thank you for the tips. I was able to get the update to install by using a different computer. I am not sure why this should make a difference, but it did.
I was accessing the router via hardware internet connection in both cases. Using Chrome updated to most recent version, and Windows 10 on the computer.
- plemansJan 19, 2022Guru - Experienced User
glad it worked!
Usually if a pc is having issues with a specific browser, a different one will work. Or clearing cache/cookies can work.
