sktn77a
Feb 28, 2025Virtuoso
R7000 2.4 GHz performance hit
Recently updated to the latest R7000 firmware V1.0.12.216_10.2.122. Around the same time (don't remember if it exactly coincided with the update) my 2.4GHs speeds have tanked. I'm only getting abou...
sktn77a
It's coming in through a cable modem that delivers 600mbps. I used to get much faster 2.4GHz speeds with a dual and tri band client (Lenovo T460) and with my iPhone 15 Pro. The fact that it's doing this on all 4 routers makes me think it's not a hardware failure but rather a software/firmware issue (it's not like this hasn't happened before with Netgear updates)!
Feb 28, 2025Guru - Experienced User
I've never seen sustained speeds on an AC router over 100mpbs. Occassional peaks maybe but not sustained. 2.4ghz is s slow network and sensitive to interference. Not sure how you were testing before but it wasn't until AX that we started seeing that 100mpbs 2.4ghz speeds.
- sktn77aFeb 28, 2025Virtuoso
"Not sure how you were testing before but it wasn't until AX that we started seeing that 100mpbs 2.4ghz speeds."
Speedtest.net
