zebo
Jan 07, 2025Aspirant
R7000, 2.4G not working
Hi Our old R7000 router recently lost 2.4 connectivity. THe 2.4G light on the router is off, or sometimes very dim, and our devices connect only to 5G. I turned off modem and router, and restarted...
JWS9518
Jan 08, 2025Luminary
You could try a hard reset and see if that fixes anything. If not, that router model is a pretty old one now and if you have had it a long time, it is likely that the electronics on the inside have given up.
