NighthawkFanboy
Oct 17, 2015Tutor
R7000 2.4Ghz & 5Ghz slowdown
Hi everyone, Got the Nighthawk R7000 a few days ago. My ISP delivers 152Mbs. CAT5e cable links my ISP Modem to the Nighthawk. Installed and set up no problem and upgraded firmware to the latest. ...
- Oct 20, 2015
Update:
When trying to troubleshoot and change channels yesterday morning... I swear that the Router login page only offered me channels 36 -40 - 44 - 48. I had tried all of them .....and offered no improvement ( from 160Mbs down to 10Mbs or something equally ridiculous).
I then updated to the latest firmware and instantly back to 160Mbs. Through the day - still strong at 160Mbs (ish) at various intervals. I checked and the channel was in the low 40's I believe.
I have 1 nieghbour using the 5Ghz band.... as I discovered.....on channel 44. So surely this would be the cause of the conflict? But why then does a factory reset or firmaware update immediately bump it back up to 160Mhz and then only first thing the next morning, it drops back to under 10Mbs? Other than my Galaxy s4 phone - no other device in the house uses the 5Ghz band.
So - via my phone this morning I access the Genie app and to my surprise, in the 5Ghz settings - a whole load of other channels. I set it to 112. Rebooted and back strong at 160Mbs ( where as before other reboots in the lower 40's made no difference).
A turn up for the books ? Hopefully. So I am either going senile way too early or the last firmware update added these previously....err...uhm.. 'missing channels'..... but they are now in the router login console....clear as day.
I can also access files and play videos off my USB drive connected to the Nighthawk....upstairs ....going through 3, 120 year old solid Victorian brick walls.... as if the drive was locally attached. So this Nighthawk (cross fingers) kicks some major butt!
So - TheEther - thank you again for your kind advice - lets hope this badboy settles down now..
NighthawkFanboy
Oct 17, 2015Tutor
Thanks for your thoughts. Well it's the next morning now and the 5Ghz band has dropped to around 50mbs so more than half. 2.4Ghz band seems Unchanged. I disconnected the USB drive last night but that doesn't seem to have made any difference.
So after a reboot now...both channels back to normal.
This is driving me nuts.
I will go back to the store and see if I can swap it for another
TheEther
Oct 18, 2015Guru
The only other thing I can suggest is to make sure the router has adequate ventilation. The buildup of heat can affect performance. If not, then I agree that making an exchange might be in order.
