jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
daywood
Jan 05, 2016Tutor
I'm having the same problem. It has been working like a champ for a couple of years and suddenly yesterday it started dropping wireless connections and losing connection with my ISP. I tried the factory reset that was suggested in another reply and then restored the settings. Now everything but the primary 2.4 GHz network is working OK. The guest 2.4 GHz network seems to be fine, so it's not an all or nothing thing for 2.4 GHz for me.. None of the devices I have can authenticate with that primary network anymore. My devices either tell me they can't connect or they tell me the password is incorrect. I tried changing the name and the password for that network but that didn't help. Anybody else seeing this variation of the problem or have any other ideas?
ikalatch
Jan 05, 2016Aspirant
Has anybody tried loading the open source firmware variants of WRT? Supposedly this router supports DD-WRT and other variants. I wonder if using some WRT flavor as a firmware would be a better fix for this issue...
- VE6CGXJun 16, 2016Master
Why don't you try? Xvortex, Tomato, dd-wrt, etc. many choices out there. When I had R7000 I never used stock firmware.
