jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
KazzMANIA
Jan 22, 2016Apprentice
Well, add me to the list. I did factory reset and rebuilt my router from scratch. I have simple setup too but have a nest thermostat and a wink home Automation hub that can only connect at 2.4ghz. Before the factory reset, my issue was exactly as described throughout this thread: perfectly reliable 5ghz and direct wire but 2.4 would just drop and devices could not connect. The devices still see the 2.4 and seem to pass it an acceptable password but keep waiting for ip to be issued. Also, I have tried turning on and off wifi switch - no change in reliability. Rebooting router or toggling the wifi on/off hard switch on the router restores 2.4 functionality but only for a while. Issue occurs again usually within 24 hours. Fails for all devices. Also fails when 5ghz is disabled. Fails with and without password protection. Fails with one device connected, 7 devices connected, or no devices connected. Watching the netgear genie app after it fails, the 2.4ghz network disappears and reappears randomly and rapidly then suddenly settles down and is visible (but not usable) for several minutes then, bam, starts hopping in and out of existence again. I have witnessed this sane behaviour when scanning for wifi using two different smart phones. After rebooting router, 2.4ghz is always visible and connectable. And, when it works, it works great. Very good signal strength and very good distance. I have moved this router to a different floor of my house - exact same issue. When I drop the router and turn on my old trendnet I have no problems at all. I need 2.4ghz to run home Automation including my thermostat! For $200, this thing is useless to me, and I have spent almost 8 days and about 40 hours wasted testing it. Worse still, I was on with tech support and they told me I had a bed radio and needed to return it to Amazon. Uhhhh, sounds like everyone is having this issue so replacing it is not going to help. NETGEAR YOU ARE KILLING ME. please help
stuckincube
The good news is that, as reported by JamesGL in an above post, "The issue has been reproduced by support team and has been forwarded already with the documentation." So now we just wait for the fix.
It is concerning that when you called Netgear tech support they had no info about this issue and just told you to return the router. How many people are getting this advice? Why hasn't Netgear phone tech support received a notice or bulletin advising them of a confrimed issue with the router that is being worked on? Maybe JamesGL can comment on that!
