jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
TheEther
Feb 01, 2016Guru
With regard to sharing the 2.4 GHz channel by the ARLO SSID and your regular SSID, there's nothing asinine about it. The guest network, when enabled, operates in the same manner, and it certainly doesn't kill the channel. There certainly could be a bug, but in the absence of this, the channel should not be significantly affected by the ARLO SSID.
You can certainly question the benefit of enabling a new feature by default, but I will point out that it is well established that features are almost never used when they are disabled by default.
ender2003
Feb 01, 2016Tutor
I do apologize for posting my complaint in multiple threads, I just wanted to be sure that anyone else searching for the same issue would be able to see it in a few different places.
- tn77Feb 01, 2016Star
Their support is NOT aware of this issue. I called and they said "it's an isolated case to your router. If this were a known issue, we would receive a bunch of calls about it."
Everyone needs to start calling, tweeting, and writing to the CEO. Netgear seriously has no idea that there is any problem here.
- NiferFeb 02, 2016NETGEAR Employee Retired
Hi tn77 -
I work for NETGEAR. Our CEO received your letter and has asked me to investigate. You should hear from one of my colleagues in the next 1-2 days, asking for more information about the issue. This will help us confirm the details of the planned fix. Thanks for bringing this to our attention.
Nifer
FYI, I was able to confirm that we have logged a bug for this issue. Now I need check on the status of the proposed fix.
- TheEtherFeb 01, 2016Guru
ender2003 wrote:I do apologize for posting my complaint in multiple threads, I just wanted to be sure that anyone else searching for the same issue would be able to see it in a few different places.
No big deal. I don't doubt that there are problems associated with the ARLO SSID, but I just wanted to point out that the reasoning might not be correct.
- KernaldFeb 01, 2016Guide
The problem described in this thread doesn't appear to be related to ARLO, I disabled ARLO as soon as I made the upgrade, the problem stayed.
